No. Only apps. Try go locker or widget locker
same exact issue with my new GS3 on VerizonYup, have to say I have had the same experience. Widgetlocker does not work, gives the error noted above. I have also tried MagicLocker and LockMenu. All have exactly the same problem. You are allowed to select a Direct Dial widget, and choose the number to dial, but when you actually try to use the control, it fails. My S3 just gives a little vibration, but nothing. I think it might be an S3 restriction somewhere - we just have to hope a developer gets their hands on an S3 and figures out the problem. I have contacted as far as I can offering to run debug versions or gather logs, but no response from any of them![]()
Is it possible to set a direct dial contact shortcut on the lock screen like you can on the home screen?
