Disable battery usage alerts
itram2001
Hello there! I use a Huawei P20 Lite, and so far I have no complaints, but there is one, only one, annoying thing about this phone, the battery usage alerts. It usually happens when I am listening to music or when a high battery usage app is running but while the screen is not on that app (don't really know how to say that). The notification that will pop up writes something along the lines of "Google Play Music is using battery" and then I can click on it to "see more details on the usage of battery and mobile data". This alone would not bother me that much, but the problem is that it removes the regular Google Play Music notification, so I can't change songs, pause, go directly to the app...
Does anyone know a solution to disable the alert completely? Thanks!
P.S.: My phone is not in english, it is in Catalan, so you might have a hard time reading that, but it says what I wrote above.
