Disable system lock screen at startup
AWAWA
I am trying to do this with tasker :
1. Enable the system pin/lock screen when I shut down the phone - done
2. then, when the phone reboots, after I log in for the first time through the system pin screen, I want to disable the system lock screen.
Is there any way to perform the second requirement in tasker?
So far I have tried commands for reboot, start monitoring, display unlock and the launch of a particular program that starts at reboot.
Nothing works. When I run these tasks manually, everything works perfectly.
I need to do this for additional security purposes at startup. My 3rd party locker starts a little while after reboot allowing access to home/apps/etc. This is a problem with all 3rd party lockers and I haven't been able to fix it, even with optimization, etc. The 3rd party locker provides many features that I want but which are not available on the system one.
I have a rooted Galaxy S3 on VZW, 4.4.2 android with Secure Settings and Tasker.
Thanks
When my phone boots it asks me for a pin and then it's disabled. I've enabled SIM-Card lock and it works great! You can find it at Settings > Security > SIM-Card lock (Might be different on your phone)
That worked! And, it also forced my locker to show up right after the sim pin unlock screen, which gives me two pins at startup now.
Thanks!
I am really careless - any way to increase the number of sim pin attempts? I suppose I'll create another thread for that question.
