Help Disable "Tap to Wake" LG Phone
How the heck do I disable the tap to wake feature on my LG Premier Pro LTE (LG LML 413 DL) Android Phone. Irt has no such option in settings.. Every time I sweat with the phone in my pocket it turns itself on and starts doing something.
If there is no way to disable, Is there some APP that will disable it.
On my LG v20 the knock on setting is found in the lower portion of the "general" settings list.
You should use Screen lock, so even if you accidentally turn it on nothing will happen.
