Disassemble for screen replacement?
My son cracked the screen on his Galaxy S Blaze. I ordered a replacement screen assembly and found a video which I thought showed how to replace the screen, but it was for a different model. I have the cover off, the flex cables disconnected and the motherboard out, but I can't figure out how to remove the old screen from the front housing. Based on the other video, it should be a combination of heating the edge of the housing with a hair dryer until the adhesive softens, then prying it off. I've tried to do this with no luck, but it could be that I'm not prying hard enough - kinda scared to break it.
Does anyone know how to remove the screen - or better yet, know of a disassembly guide for the Galaxy S Blaze?
Thanks!
