Help Discover having trouble staying connected to wifi
sprtjnkie
A friend recently bought a Discover after her old phone took a spill on a recent trip. Everything seems great she says but she can't keep wifi connected. It keeps dropping even while the phone is awake. She's tried "forgetting" the network and connecting again but the same issue keeps popping up. She's also having trouble with MMS messages and being able to open them. Not sure if this is a related issue or not, just throwing it out there as well.
This phone is still rather new but does anyone have any ideas what may be the cause or fixes to try? Thanks!
I've had the same issues on my previous phone. To correct the problem, I re-set the router and it did the trick. As for the MMS messaging, I had to have a full 4G signal to receive them, as they do not work with wifi. If the signal is weak, then it most likely will not download.
Hope this is helpful :idea:
