Discoverable mode
Is there a way to force the Motorola Droid to stay in Discoverable mode? Would it kill battery life? I am looking into a smart home lock that could be controlled by they phone via bluetooth. The only problem is that the phone needs to be in discoverable mode for the device to find it.
that sounds strange are you sure you are reading the directions correctly? usually blue-tooth devices require discoverable mode for the initial pairing and then they find each other automatically when turned on after that.
