Well after weeks of trying to figure out what was causing my battery drain, I have finally figured it out.
Lightflow was the major cause, as the number of wakelocks on my phone was over 10,000. I actually had been using gsam for the past 2 weeks but just simply overlooked all the tabs that it offered. Although android system was the culprit for battery percentage, the hidden app was in fat discovered under the "num times held awake" through the gsam app.
When i uninstalled lightflow, i went from 40% "android system" down to 10%. Getting much better battery life now. I am at 38% now off a 12 hour day, but only about 50 minutes of screen time. Thats actually much better than before, so for now I am happy, and of course I can always buy a spare battery.
This is a relief but a dissapointment at the same time. I really enjoyed the LED customization and now I cannot use it. I emailed the developer and hope they have a fix for this. If anyone else is using another LED custom app that isn't harsh on the battery, let me know please!
Hope this helps anyone.
