Help display problem(s)
jlede
Android Expert
So I've had my tablet for almost a year now and I have a slight orange discolor around the edges of my display how to fix or do I just buy a new display (short on cash trying to get a nexus 5) any ideas
"Fixing" it probably requires some pretty fancy chemistry, so the only choices are replacing it or living with it. And considering the cost of replacing it (you don't just buy a new display - unless you want to pay to fix all the damage you cause when you try to replace the original one) and the fact that you're trying to save for that Nexus, I'd live with it.
Alright then just trying to see if anyway possible someone could help I'll just live with it thanks again (already hit the thanks button)
