Display Temperature on Lock Screen
parkschr
Is there an app that allows the temperature to be displayed on the locked screen? My lock screen is the "draw the pattern" lock.
I am asking since it is very difficult to see the temperature now in the upper left hand corner since the ICS update. Too small and too dim.
Thanks
Some weather apps (Beautiful Widgets, WeatherBug, Fancy Widgets, etc) let you see the weather in the notification bar, so that's another option. I use WidgetLocker and it works great too!
I use the "AccuWeather for Android" app, which is not the one that comes with the phone, it's the full app which you can download for free and it has the option to view the current temp in the notification bar if you want it there.
It's the best weather app I've used to date. Has 10 day, hourly, satelite, etc.
