Go back to the lockscreen settings and and set it to swipe.I set up my phone to unlock with a code number, How do I set it to unlock without one? Running Android version 5.1.
Follow this path:I set up my phone to unlock with a code number, How do I set it to unlock without one? Running Android version 5.1.
No. You definitely need 'screen lock.'Unfortunately, this menu pattern is different on my phone, an unlocked LG G4 with Android 5.1, build LMY47D, Software version US9111A.
I did find it, though, under Security/Content lock/Set lock. But the menu defines content lock as "lock files for Gallery and memos for QuickMemo+"--is that the same thing?
Your question might be more relevant if you asked where LG put it in their Settings menu set up. Some manufacturers opt to leave the base Android interface as is, some of them like to modify and alter the interface to suit their own purposes. Try and see if this applies:Anybody know where that is on Android 5.1?
On *my* 5.1 phone, it's the exact path I posted. Mine is a Moto X 2nd Generation.Anybody know where that is on Android 5.1?
