saltire
Android Expert
Have never successfully resolved this and may never be able to
but posting here can't hurt just in case.
So I have a NAS with wired connection to router and wired connection from router to Onkyo CR-N755 network hi-fi via Solwise home plugs. Can access NAS fine from Onkyo direct, but interface is very limited (single line onscreen display) and searching for stuff using the remote is hopeless. Handily Onkyo do have an Android app which takes some of the pain away, but there is frustratingly no way to create playlists and browsing/searching through my library is clunky at best. So thought I'd try Bubble uPnP app, which looked to be a much better interface all round. Picked up the NAS fine, picked up the Onkyo as renderer fine. But no matter what I try every time I select something to play I get a 'Transport is Locked : code 705' error appearing.
At first I thought it was my BT HH3 locking something out, but have recently just upgraded to a TP-LINK Archer and still no luck. UPnP is enabled on the router, have tried directly selecting NET > DLNA source on the Onkyo first and then trying to play something using Bubble, checked for a firmware update from Onkyo but there has been none at all released for my system - no joy nothing works. Been searching off and on for a while and can't find anything that might help, but suspect that it is down to the Onkyo unit itself and the dlna/upnp implementation.
I realise that dlna/upnp can be (is?) a minefield - but any suggestions or pointers would be much appreciated. Even if it is to another app similar to Bubble that I could try. Although there are a lot of other apps I've had a look at, they all seem to be either for accessing/playing media from external sources on my phone, or playing locally stored media on my phone to an external renderer. I only want my phone or tablet to be the control point though.
Thanks for taking some time to read anyway
