Does Anyone Have a T-Mobile Marshmallow or Lollipop .kdz?
Juncojam
I have the MetroPCS LG G Stylo running on the T-Mobile .kdz on 6.0 Marshmallow. I was trying to unroot it, and after that, it went into a bootloop. Does anyone have a marshmallow or lollipop .kdz and ways to re-root? Any help is greatly appreciated.
Try that.
update;
ok got it
Pull you battery and tell me the firmware ver and I can set you up.
don't use the 6.0 I sent you, go 100% back to stock .
Practice getting into download mode till you get a chance to total wipe and install with the flash tools.
Try that.
update;
ok got it
Im certain that i can get into download mode without a problem. It's the black screen that's throwing me off. Idk if its a hardware issue or only because i flashed a .kdz the wrong way
Jeez. Black screen? Like is it stuck? What happens when you go into Device Manager when plugged into a computer. Just curious.
Same as your phone does it goes into d/l mode so you can flash a tot or kdz file. Come on a month later. There is some reading required obviously. Lol
well when the phone was like that, the computer could detect it and everything. only thing was that i was sure its default was charge only mode, so the computer couldn't read my phone. i could get calls, but the screen was completely black, so at the moment, it was completely useless until i could flash a .kdz
