I have root and stock RomHello
Are you rooted? Running a stock or custom rom?
I didn't backupI doubt you will have much luck in finding these. Did you back up your ROM? If not you will need to find one for your device
Can you help me to get a linkHm, I was thinking about finding a stock rom, download it to the computer, pulling the files he needs out of it, and pushing them to the correct file path, set permissions, reboot. (using a file browser such as root explorer)
I'll see what I can find...I'm at work right now.Can you help me to get a link
Thanku so much for advice
I"ll check back later. If someone else hasn't chimed in with it, just rattle my cage later ok?(that means "let me know"
Edit: by the way, can you post your device model number and android version? That may help find what you need
By the way my device is Sony xperia tipo st21i and stock Rom firmware 11.0.A.4.27I'll see what I can find...I'm at work right now.
