Does Mabilo Ringtones not work on incredible?
gripweed
I went into mabilo and selected a ringtone and notification alert and they don't seem stay. My default notification still sounds off.
oh man...now I somehow set Zedge as my default when I go to pick ringtones/notifications and I can't figure out how to undo that.
Any help?
NEVERMIND, SOLVED THIS ISSUE.
mabilo works on my incredible
i have noticed that when i go to charge my phone/install something (Use as a disk drive in the charging options) and i unplug the phone from the charger i have to turn the phone off and then back on occasion to get my ringtones/notifications to start working right again.
Only had the problem while the phone is in the: Use as a disk drive state
Hm, I can't get Mabilo or Zedge to work.
Well, they work, I can get ringtones and what not and they show up in my list and everything but if I select the ringtone, it doesn't stay, it just goes back to the default.
Make sure when you apply ringtones to callers, their phone number includes the numbers 1(area code)phone number.
The phone number without the area code preceding it is the main reason why your ringtones will not work,
