Help Does not start up
JOESCHOE
I have been using my IdeaTab A2107 for about a month now. This morning, after I had installed Splashtop and used it for half an hour, I closed the splashtop running on my PC, and the the tablet went blank.
I have not been able to get it to start up again.
I would hate to have to reinstall all the apps and download all the reference books I have loaded, however, I cant even get the start up screento display.
When I press the power button, nothing happens, not even a vibration.
Must I return the machine to the supplier or is there something else I can try?
There is a reset button.
Remove the back cover and you'll see a little white dot underneath the camera lens. Press it gently with something blunt, like a PDA stylus, and then try turning on again. .
Just an FYI, the reset button isn't a true reset button, but a disconnect for the battery. It's in line with the power connector on the board.
