Help Dolphin status bar not going away after JB update
Ever since the JB update on Verizon my Dolphin browser status bar no longer disappears when scrolling down a web page. Before when I opened a web page and then scrolled down the status bar would also scroll up and disappear until I scrolled back to the top. Now the status bar is always there taking space on my screen. I know that I can select the Fullscreen mode, but I didn't have to do that before. Is there a setting that I am overlooking that maybe changed since the update? Or maybe that's just the way it is now?
Since posting the above question I have done some more searching and I found others with the same issue. It appears to be due to Dolphin's latest update, so I sent them an email. We'll see how it goes, but so far it's been my favorite browser.
Same here. Enabling Jetpack helped. I emailed them before the last two updates about the issue and they said they'd look into it. Hopefully it's fixed in the next major release.
How do you enable Jetpack? I remember when that first came out it was right there on the main settings page, but I don't see it anymore. For now I've been getting more familiar with the full screen mode.
Should still be. Check the Play Store for updates in case Jetpack is just out of date and not appearing. If everything's up-to-date, I would try uninstalling and reinstalling Jetpack.
