[Donwload]-[ROM]-]KrakenOS 13]-[SEMI ESTABLE]-[FOR-CODINALTE]
NENORRA
INGLES
MESSAGE FOR CODINALTE USERS ACE 2 AND MORE
KraKenOS 13 BETA 1 REMEMBER THAT IT IS BETA
CM13 of meticulus has enough bugs remember that its version is alpha
and what I did is to establish more that alpha
I take a break to see the rotosion and wifi failures
this version of mine is much more stable in wifi and rotasion
in battery it's the same as the base
BUGS
As I said before, the 1beta is more stable but not so much
ROTATION
Rotation stops working (BUT) abeses when it rotates in an app whatever it is
as it stops working systemUI (EYE) I say as stop stop working
but the rotasion continues to work
the wifi reconnects but avese does strange things is still testing is more stable
but not enough for the self-reconceptive (EYE) can coectarte your
manually, (just stop working the reonecsio) you are not sure it stops working
THEY ARE ALL THE BUGS THAT FOUND ALL THIS DAY THAT WAS OF PRUBRALA
PREVIOUS MIND AVIA SAID THAT WIFI AND ROTASION, BUT AFTER 1 OR 2 HOURS LEFT OF FUNSIONAR
AND THAT'S WHY BETTER I DID NOT TAKE SOME BETA SINCE IT WAS NOT ALL SECURE
APPS / OPTIMIZASION
ALL OF THOSE APPS OF PERSONALISASION CONTACTS BROWSER ETC WAS REMOVED
THE SYSTEM IS ENOUGH FLUID THAT IS FOR WHAT IS DESIGNED KrakenOS
KEYBOARD ADDED WITH NUMERICAL ROW AS AVIA SAID
ADD NEW SCREEN FUND
THE LAUNCHER WAS CANBIO BY ONE MORE UPTIMIZED AND MORE LIBIANO
THE GALLERY WAS CANNED BY OMNIROM
IT DOES NOT WORSHIP ANY OF THE FOLLOWING DEVICE TO APPS THAT WERE REMOVED
CALLS
CONTACTS
INPRESS
PERSONALISASION (ONLY IF A LAUNCHER THAT APMITS PERSONALIZATION IS INTALED)
FEATURE / FUTURE
IF THE THEME OF THE BATTERY CONTINUES TO BE CHANGE OR WILL TRY TO CHANGE THE KERNEL
I HAVE THOUGHT IN MAKING A BASE 6.0.1 FOR CODINALTE FOR IF SOMEBODY OF CODINALTE WANTS TO MAKE ITS ROM
HO DO SOMETHING ABOUT MY BASE
LEAVE BETTER THE THEME OF WIFI AND ROTASION AND MORE
INSTALLATION
make wipe
everything but sdcard
have twrp 3.0.1-0 since it was where I installed
It is not known if it can be done in CMW
make dalvick wipe after installing
ALL CREDITS FROM THE BASE TO METICULUS
AND ALL CREDITS DELA ROM AND AMI :)
DOWNLOAD KRAKEN 13 SEMI STABLE
https://mega.nz/#!75tW0Q6I!tBfFHXEDswhsezzpkG0Gsu5XFg5S-Sp6Z0IIFda4aPo
SOON WILL BE PUBLISHED IN MEDIAFIRE AND MORE
ESPAÑOL
MENSAGE PARA USUARIOS DE CODINALTE ACE 2 AND MORE
KraKenOS 13 BETA 1 RECUERDA QUE ES BETA
CM13 de meticulus tiene bastante bugs recuerda que su version es alpha
y yo lo que hice es estableser mas esa alpha
me tome un descanso para ver vien los fallos de rotasion y de wifi
esta version mia es mucho mas estable en wifi y rotasion
en bateria sigue igual que la base
BUGS
como dije antes la 1beta es mas estable pero no tanto
ROTASION
La rotasion parese funsionar (PERO) abeses cuando rota en una app da igual cual sea
como que deja de funsionar systemUI (OJO) digo como que parese dejar de funsionar
pero la rotasion sigue funsionando
el wifi reconecta pero avese hace cosas raras se sigue testando es mas estable
pero no lo sufsiente para la auto-reconecsion (OJO) puede coectarte tu
manualmente,(solo deja de funsionar la reonecsio) no se esta seguro se deja de funsionar
SON TODOS LOS BUGS QUE SE ENCONTRARON TODO ESTE DIA QUE FUE DE PRUBRALA
ANTERIOR MENTE AVIA DICHO QUE WIFI Y ROTASION,PERO DEPUES DE 1 O 2 HORAS DEJABA DE FUNSIONAR
Y POR ESO MEJOR NO SAQUE DICHA BETA YA QUE NO ESTABA DEL TODO SEGURO
APPS/OPTIMIZASION
SE QUITARON TODAS ESAS APPS DE PERSONALISASION CONTACTOS BROWSER ETC
EL SYSTEMA VA BASTANTE FLUIDO QUE ES PARA LO QUE ESTA DISEÑADO KrakenOS
SE AGREGO TECLADO CON FILA NUMERICA COMO AVIA DICHO
SE AGREGO NUEVO FONDO DE PANTALLA
SE CANBIO EL LAUNCHER POR UNO MAS UPTIMIZADO Y MAS LIBIANO
SE CANBIO LA GALERIA POR LA DE OMNIROM
NO FUNSIONA NADA DE LO SIGUIENTE DEVIDO A APPS QUE SE QUITARON
LLAMADAS
CONTACTOS
INPRIMIR
PERSONALISASION (SOLO SI SE INTALA UN LAUNCHER QUE APMITA PERSONALIZASION)
FEATURE/FUTURO
SI EL TEMA DELA BATERIA SIGUE IGUAL SE CANBIARA O SE INTENTARA CANBIAR EL KERNEL
TENGO PENSADO EN HACER UNA BASE 6.0.1 PARA CODINALTE POR SI ALGUIEN DE CODINALTE QUIERE HACER SU ROM
HO HACER ALGO SOBRE MI BASE
DEJAR MEJOR EL TEMA DE WIFI Y ROTASION Y MAS
INSTALASION
hacer wipe
de todo menos de sdcard
tener twrp 3.0.1-0 ya que fue en la que se instalo
no se sabe si se puede en CMW
hacer wipe de dalvick despues de instalar
TODOS LOS CRÉDITOS DE LA BASE A METICULUS
Y TODOS LOS CREDITOS DELA ROM Y AMI :)
INSTALLATION
make wipe
DESCARGAR KRAKENOS 13 SEMI ESTABLE
PRONTO SE PUBLICARÁ EN MEDIAFIRE Y MÁS
