Apps Download Zip to SD card, zip not getting read
cul
hello there, tried following code to download zip to sd card, i get NullpointerException. when tried some interrogations i come to know that the zip file is not getting downloaded actually. So would you please help whether code needs some changes or anything wrong with zip? M stuck on that point only. Please help... my code as follows... help appreciated... :confused:
Code:
        setContentView(R.layout.main);
        String from = "http://192.168.1.63/ZipFile/Text.zip" ;
        String to = Environment.getExternalStorageDirectory() + "/newunzip/";
        try {
            ((TextView) findViewById(R.id.display)).append("\n in try after function :");
            downloadFile(from, to);
        } catch (Exception e) {
            // TODO Auto-generated catch block
            e.printStackTrace();
            ((TextView) findViewById(R.id.display)).append("\n \n Exception occured :");
            ((TextView) findViewById(R.id.display)).append("\n \n Exception message is :"+e.getMessage());
            ((TextView) findViewById(R.id.display)).append("\n \n Exception is :"+e.toString());
    private void downloadFile(String from, String to) throws Exception
        ((TextView) findViewById(R.id.display)).append("\n \n in function call :");
        HttpURLConnection conn = (HttpURLConnection)new URL(from).openConnection();
        conn.setDoInput(true);
        conn.setConnectTimeout(100000); // timeout 100 secs
        conn.connect();
        ((TextView) findViewById(R.id.display)).append("\n \n Connecting to url :"+ conn);
        InputStream input = conn.getInputStream();
        byte[] b = null;
        input.read(b);
        ((TextView) findViewById(R.id.display)).append("\n \n input method :"+ b);
        FileOutputStream fOut = new FileOutputStream(to);
        byte[] b1 = null;
        input.read(b1);
        ((TextView) findViewById(R.id.display)).append("\n \n output method :"+ b1);
        int byteCount = 0;
        byte[] buffer = new byte[4096];
        int bytesRead = -1;
        while ((bytesRead = input.read(buffer)) != -1)
            ((TextView) findViewById(R.id.display)).append("\n \n reading/writing files :");
            fOut.write(buffer, 0, bytesRead);
            byteCount += bytesRead;
        fOut.flush();
        ((TextView) findViewById(R.id.display)).append("\n \n flush & close :");
        fOut.close();
Post the excpetion your getting in logcat here. This will make it much easier for us to help you.
Hello there, due to the point at Android OS is based on Linux .zip files are not supported, but I am sure .rar is :), Feel free to PM me if you need anymore help.
Thanks,
Dylan
OK thanx for your reply guys! first of all .zip is not getting downloaded which i resolved with using "astro" in which I've given permission to download all files.
But after that it's not going to download that file instead it giving null pointer exception... n no other message it's generating. only null pointer exception, m stuck here badly.. :( plz help me out!
