Downloadable globe icon to click for internet possible ?
I want to download a globe Icon to put on my home screen so that I can click on it for the internet (www.google.co.uk) is it possible which type jpg etc, also can you add this to the main menu with all the other in built Icons ?
Put another way can I swap an Icon which is a short cut to a given website to a different downloaded Icon or otherwise ?
Its ok I have set the home page of the browser to google.co.uk, I did not like it comming up with the orange website by default as I am on the orange network, and had another Icon on the home screen which went direct to google.co.uk after I made it a short cut but wanted to change the Icon as it was red and did not look right, anyway after looking on the net found that there is some software which will allow you to change Icons on the home screen, but not sure if they will change the Icons on the main menu pages as well, but I am fine now with setting the normal Icon to the google home page
I'm not sure if this is what you are looking for but if you go to maxthon.com you can design your own browser. If you look up the maxthon browser in the play store, you can read the fantastic ratings. It is more fun to go to the website & design your own than to get it from the playstore though. I did exactly what you mentioned. I just did Google image searches for the planet earth. If you do the globe, you get pics of them on stands. You need some kind of photo editor though because you have to take the pixels I believe to 72x72, you can also choose a splash screen that shows when you start the browser. Inside the browser is very customizable. You should give it a go.
