murdercityriot
Hi,
I'm not sure if I'm doing something wrong or I've misunderstood how density-independent pixels work.
I'm trying to build a layout that scales in proportion for any screen size, but as you can see in the screenshots below, the text and the other parts I've defined in DP don't scale properly on larger screens.
My layout XML is:
My layout XML is:
Code:
<?xml version="1.0" encoding="utf-8"?>
<LinearLayout
android:orientation="vertical"
android:layout_width="fill_parent"
android:layout_height="fill_parent"
xmlns:android="http://schemas.android.com/apk/res/android">
<TextView
android:background="#F995D0"
android:id="@+id/TextView01"
android:textColor="#FFFFFF"
android:typeface="sans"
android:layout_gravity="center_horizontal"
android:gravity="bottom|right"
android:paddingRight="5dp"
android:layout_height="100dp"
android:textStyle="bold"
android:textSize="32dp"
android:text="text1" />
<LinearLayout
android:background="#FFFFFF"
android:paddingBottom="40dp"
android:paddingTop="30dp"
xmlns:android="http://schemas.android.com/apk/res/android" >
<TextView
android:layout_weight="1"
android:id="@+id/TextView02"
android:gravity="left|center_vertical"
android:paddingLeft="15dp"
android:background="@drawable/rounded_edges"
android:layout_width="250dp"
android:layout_gravity="right"
android:textSize="25dp"
android:layout_marginRight="-10dp"
android:layout_marginTop="10dp"
android:text="text2" />
<TextView android:layout_weight="1" android:id="@+id/TextView01" android:textColor="#FFFFFF" android:typeface="sans" android:gravity="left|center_vertical" android:background="@drawable/rounded_edges" android:layout_width="250dp" android:layout_gravity="right" android:textStyle="bold" android:layout_marginRight="-10dp" android:paddingLeft="15dp" android:layout_height="fill_parent" android:layout_marginTop="10dp" android:textSize="25dp" android:text="text3"></TextView>
<TextView android:layout_weight="1" android:layout_marginRight="-10dp" android:textColor="#FFFFFF" android:background="@drawable/rounded_edges" android:paddingLeft="15px" android:textStyle="bold" android:layout_width="250dp" android:typeface="sans" android:gravity="left|center_vertical" android:layout_gravity="right" android:id="@+id/TextView03" android:textSize="25dp" android:layout_height="fill_parent" android:layout_marginTop="10dp" android:text="text4"></TextView>
</LinearLayout>
</LinearLayout>
