draining battery
I have a Samsung Galaxy S3. It will be 2 yrs in August that I have had the phone. T Mobile is my car
  • 2
    Votes: 0 0.0%
  • 2
    Votes: 0 0.0%
  • Total voters
    0
  • Poll closed .
DEB R A
I have a Samsung Galaxy S3. It will be 2 yrs in August that I have had the phone. T Mobile is my carrier. For about the last month my battery has been draining. I bought a new battery and that is not the problem. After charging the new battery I was able to use it for 2 days without charging it. I put it on the charger last night and this morning as soon as I took it off the charger it lost half of it's charge and within 20 minutes it was dead. Could you tell me what is draining my battery and how can I fix this. Thanks DEB R A
Try going into your Settings >> More >> Battery and see if anything out of sorts stands out. If you tap on the graph it should expand, if you tap on the listed apps/processes most will show more details.
As @svim suggested,go to settings and find battery. Should show something similar with break down of what is using battery
