BlackHawkDown00
Hello everybody,
I have created an Android 5.1 application with which I can write with a stylus on a tablet using SurfaceView and Canvas. You can find my code below. Unfortunately, the writing is very slow, especially when lot of text is written it starts getting slow. I think the problem is that it is rendered in software. Of course, a possibility to speedup would be to use OpenGL but I don't know it and I think this has a too steep learning curve for me right now.
Nevertheless, is there a possibility to speedup my code (i.e. to make it more responsible when writing)? Or else is it easy to change my code to OpenGL?
Code:
public class DrawingView extends SurfaceView implements OnTouchListener {
private Bitmap mBitmap;
private Canvas m_Canvas;
private Path m_Path;
private Paint m_Paint;
private ArrayList<Pair<Path, Paint>> paths = new ArrayList<>();
private float mX, mY;
private static final float TOUCH_TOLERANCE = 4;
private boolean isEraserActive = false;
private int pathCount = 0;
private View rectangleView;
public DrawingView(Context context, AttributeSet attr) {
super(context, attr);
setFocusable(true);
setFocusableInTouchMode(true);
setBackgroundColor(Color.TRANSPARENT);
this.setOnTouchListener(this);
onCanvasInitialization();
setAlpha(0.99f);
public void onCanvasInitialization() {
m_Paint = new Paint();
m_Paint.setAntiAlias(true);
m_Paint.setDither(true);
m_Paint.setColor(Color.parseColor("#000000"));
m_Paint.setStyle(Paint.Style.STROKE);
m_Paint.setStrokeJoin(Paint.Join.ROUND);
m_Paint.setStrokeCap(Paint.Cap.ROUND);
m_Paint.setStrokeWidth(2);
m_Path = new Path();
Paint newPaint = new Paint(m_Paint);
paths.add(new Pair<>(m_Path, newPaint));
@Override
protected void onSizeChanged(int w, int h, int oldw, int oldh) {
super.onSizeChanged(w, h, oldw, oldh);
mBitmap = Bitmap.createBitmap(w, h, Bitmap.Config.ARGB_4444);
m_Canvas = new Canvas(mBitmap);
@Override
public boolean onTouch(View arg0, MotionEvent event) {
float x = event.getX();
float y = event.getY();
if (rectangleView != null) {
ConstraintLayout.LayoutParams params = (ConstraintLayout.LayoutParams) rectangleView.getLayoutParams();
params.leftMargin = (int) x;
params.topMargin = (int) y;
rectangleView.setLayoutParams(params);
return true;
} else {
if (event.getToolType(0) == MotionEvent.TOOL_TYPE_ERASER) {
isEraserActive = true;
} else {
switch (event.getAction()) {
case MotionEvent.ACTION_DOWN:
touch_start(x, y);
invalidate();
break;
case MotionEvent.ACTION_MOVE:
touch_move(x, y);
invalidate();
break;
case MotionEvent.ACTION_UP:
touch_up();
invalidate();
break;
return true;
@Override
protected void onDraw(Canvas canvas) {
for (Pair<Path, Paint> p : paths) {
canvas.drawPath(p.first, p.second);
private void touch_start(float x, float y) {
if (isEraserActive) {
m_Paint.setStrokeWidth(20);
m_Paint.setXfermode(new PorterDuffXfermode(PorterDuff.Mode.CLEAR));
} else {
m_Paint.setColor(Color.BLACK);
m_Paint.setXfermode(null);
pathCount++;
m_Path.reset();
m_Path.moveTo(x, y);
mX = x;
mY = y;
private void touch_move(float x, float y) {
float dx = Math.abs(x - mX);
float dy = Math.abs(y - mY);
if (dx >= TOUCH_TOLERANCE || dy >= TOUCH_TOLERANCE) {
m_Path.quadTo(mX, mY, (x + mX) / 2, (y + mY) / 2);
mX = x;
mY = y;
private void touch_up() {
m_Path.lineTo(mX, mY);
m_Canvas.drawPath(m_Path, m_Paint);
public void reset() {
p.first.reset();
paths.clear();
pathCount = 0;
mBitmap.eraseColor(Color.TRANSPARENT);
invalidate();
