Help Drive mode call answering
I don't have Bluetooth in my car, so my DT2 sound is wired to my stereo.
When I answer a call while driving (always by voice command), the sound will not automatically go out the sound aux wire to the stereo - I must hit the speakerphone button.
Is there a setting adjustment I can make to correct this?
I'm sorry to say that I can't think of one. I know that the touchless control feature on Jellybean and KitKat on the 2013 Droids and the 2013 Moto X had a setting you could change to make all voice controlled *outgoing* calls use the speakerphone, but I'm not sure about incoming calls using the drive assists feature, and I'm really not sure if it worked if you had earbuds plugged in. (I never received a call when I was plugged in to the aux jack that way with my phone.)
You would think that all call audio would go out when it sensed a plugged-in headset, but maybe it won't do so if you don't have an audio/microphone combination cable?
This may be worth making a call to Motorola support to see if they know of a solution. Good luck, I hope that you find an answer.
