Help driver software was not successfuly installed
shain00
Member
for some reason my m835 software isnt working, the photo explains it all
actually yes i fixed mine go to 3g on m835 on the second page
OK, for everyone that is having problems getting the "DBAadapter Reserved Interface (COMxx)" listen up. This may not work for you, but this is how I got mine to work.
At first, when I would plug in my m835 (Mate35 ROM), with USB debugging enabled, and port setting to "Manufacturer Mode", all I would get would be 4 unrecognized "Android Adapters".
My roommate has an stock M860, which is basically the exact same phone with a bigger screen. I copied the drivers from his phone's fake CD-ROM that is loaded when it is USB connected to a folder on my hard drive.
I then reconnected my phone, with USB debugging and Manufacture mode, went into device manager, uninstalled those 4 "Android Adapters", and chose to delete the drivers.
I then ran the PcOptions.exe from the m860 drivers folder, which installed the drivers to my PC. When I reconnected my m835, instead of 4 unrecognized Android Adapters, I got the following:
Android Adapter ADB Interface
Android Adapter Modem
Android Adapter PCUI (COM6)
Android Adapter Reserved Interface (COM8)
I was then able to follow the instructions for updating my PRL. I got the 3G icon very briefly on US1, just south of Taft St. in Hollywood, FL, but not long enough to test anything. Will keep a watch on it though as I travel around Hollywood/Ft. Lauderdale.
^.^ followed these guides step by step and also:
Here is a guide (borrowed from the Ascend threads) on how to update the PRL on the Huawei M835
http://forum.xda-developers.com/attachment.php?attachmentid=718949&d=1315954146 <--3022.prl
Install Drivers
On Phone Dial this code
*#*#2846579#*#*
A menu will pop up
Then
Go to projectmenu -- Background Settings -- USB Port -- (select) Manufacture mode
Go to www.checkesnfree.com to get your SPC code with your MEID number from under the battery.
Make sure on Phone USB Debugging is on
Now On Windows go to device manager -- ports and look for DBAdapter Reserved Interface
(Remember your COM PORT)
Run QPST Configuration (located in startmenu -- all programs -- QPST)
Add new port (Add COM port from Device Manager DBADAPTER Interface) ..
Then Go to start client -- service programming
On Service Programming
Go to tab roam
Look for preferred roaming (Browse for the 3022.prl file given )
click read from phone ......
when asked for code enter the MetroPCS SPC number
Then Hit Write To Phone
If Successfull Phone Will Reboot (You will Have 3G icon If in Coverage Areas)
dont forget to thank them
i also wouldn't worry about driver max, i used it and thats how i got my android modem and adb interface com jacked up, just delete them and uninstall them and replace them with the drivers in that link.
