I just replaced my Droid 2's digitizer, and I am not able to pull down my notification bar. I opened settings>dev options>show touches, and I found out my new digitizer doesn't read the top 1/4th inch of the screen, right where the notification bar is. It's usable, but I have to put it in landscape whenever I want to use the notif bar.
Also, when scrolling it used to be smooth, but if I scroll slow, it jumps every once in a while, and will sometimes think there was a touch when there wasn't.
Did I get a bad digitizer?
Could the installation be the problem?
Check out step 31...
ww w.ifixi t.com/Guide/Installing-Motorola-Droid-2-Front-Panel/3506/4
remove spaces from link
Thanks!
Thanks!
