Droid Bionic not charging correctly
RBnewbie
Hello all -
I recently got a droid bionic ( couple of months ago ) - When I plug in the charger, the charge level of the battery seems to decrease 80% -60% -40%, etc. I generally keep the phone on the charger, at home and in the car. It just started this behavior. Any suugestions? Thanks
RB
Hello all -
RB
I would bet that it is a hardware issue, I would look into a RMA given that the device is a couple months old.
Welcome to the AF, look around and enjoy. :beerglass:
Be sure to check out the sections dedicated to your Android device and your Carrier.
Also if you want to be able to connect to the Forums from your Android device, be sure to check out the free Phandroid app in the Google Play Market. Cheers!!!!
I woke up the other morning to a dead Bionic. Charger wouldn't charge it. No previous problems. Tech said it was software issue, sent me a refurbished replacement. Charger charged it up. Now this evening charger not charging it. Switched outlets, checked wire connections, still not charging. Borrowed friends charger (different type) and no problems. I think the Bionic charger was the problem to begin with. I'll definitely be buying a new charger tomorrow.
