Droid Flashlight is an application that uses the flash on your Droid as a flashlight. This requires root but should work on Eclair and Froyo on the Droid. The following features are also available in the application:
- Use flash as flashlight
- Morse code converter (type in a string and the application flashes out the text in morse code using your camera flash)
- SMS notify (use camera flash as a notification of a new SMS, useful for dark places)
- Strobe (use camera flash as a strobe light)
- Widget for turning on and off LED
Should work on the Droid X as well (for Eclair or Froyo), but if you own a Droid X I would recommend purchasing Droid X Flashlight (made specifically for the Droid X).
Edit* Sorry this should be in App Announcements, please move.
