Droid Pro update to .3.8.7.XT610.Verizon.en.US
Wonder if it supports root??
I saw a post by Android wizard extraordinaire, CellZealot, over at MyDroidForums, who claims :
"... it supports root and is an excellent build. It also supports using the band unlock and GSM performance is far superior to the previous radio firmware. Overall this build is incredibly stable and without question the best build yet for this phone."
That's good enough for me.
This was already my favorite phone that I've ever owned, and this update has made it even better. Everything is so much smoother and the battery life has been greatly improved.
does anyone know what exactly was "updated" in this update?
EDIT: FOUND IT!
Software Update for the DROID Pro by Motorola
Introduction
We are pleased to announce the new software update for DROID Pro by Motorola. This software update by Motorola (Version.3.8.7.XT610.Verizon.en.US) brings along data encryption of onboard and micro SD card memory along with many other enhancements. Upgrade today to take advantage of great enhancements and new enterprise capabilities.
For more information on Motorola updates and product support, visit us at www.motorola.com/mydroidpro.
Who Can Use This Release
ALL Motorola DROID Pro users.
After downloading and installing the software release, you will notice:
New Features
Device and SD card encryption
Encrypts files in device memory and/or SD card with AES256 encryption and auto-generated device key.
ActiveSync policies used to control encryption
Device encryption enabled
Require Device Encryption
Require storage card encryption
Additional ActiveSync policies
Require manual synchronization while roaming
Allow HTML E-mail
Attachments enabled
Maximum attachment size
Maximum calendar age filter
Maximum e-mail age filter
Maximum HTML e-mail body truncation size
Maximum e-mail body truncation size
VPN enhancements
IPSec VPN client is now consolidated with Google's VPN UI Settings instead of being standalone app.
HTTP proxy in Wi-Fi
Allows you to set a proxy server in Wi-Fi settings so users can access external HTTP/HTTPS sites when camped on corporate Wireless.
VCAST
Application store now preloaded.
Enhancements and Improvements:
-Within the Exchange ActiveSync initial email account configuration, you will be prompted to enter a server name.
-Exchange ActiveSync email delivery delays have been corrected.
-Exchange ActiveSync calendar event syncing improvements.
-Calendar events will no longer be deleted from your device if the meeting is updated.
-Device will now allow Wi-Fi users to access external corporate networks.
-Text messages will not display the wrong recipient.
-Global Customers can now re-register on non-CDMA networks after Airplane mode is exited.
-The on-screen clock times remains up-to-date.
-Bluetooth
This just installed on my phone this morning.
After it rebooted, the battery indicator is now black with a white question mark. I plug it into the charger and it says:
Invalid Battery
You device battery is invalid and cannot be charged.
Replace the battery with an original Motorola battery.
The battery is factory and was working just fine before the update. Something in this update is causing this.
Invalid Battery
First I've read about that. Mine is perfectly fine at reading the stock batter and the OEM extended battery. It's probably something in the update not working right with something on your phone (or files that didn't install properly).
I pulled the battery and then put it back in. Everything is working normally now. Not sure what happened, but it was immediately after the update was installed.
  • apparently this is a 43.8MB file
  • updated Blur
  • not Gingerbread
Don't know if this is typical, but when I try to root my updated phone using z4root 1.3.0, z4's busy indicator spins for about 5 minutes, then the phone hangs hard - have to remove the battery to recover. Looking for a solution.
z4root does not work with the latest update.
aRoot does work:
Download aRoot!
I had to install the latest Motorola USB drivers found here:
USB and PC Charging Drivers - Motorola Mobility, Inc. USA
After installing those (if you're not already up to date), connect your phone to your PC in "Charge Only" mode, extract the aRoot files, double click on aRoot.bat, watch it do it's thing, your phone will reboot, and then you're rooted.
I was prompted to install the update this past weekend, which I happily did. Since then, however, I have noticed a considerable reduction in the phone's performance. It's very sluggish and hangs a lot (when scrolling through emails, typing text messages, scrolling through websites, moving between home screens, etc.)... very annoying. Has anyone else experienced this? Any suggestions? I've pulled the battery multiple times and haven't installed any apps since the update.
Were you rooted when you installed the update? That seems to be causing a variety of problems for people.
I was rooted when I installed the update and am having the same problems as ms244 is describing. Any way to fix this issue? I haven't rooted again yet using aRoot like you described.
Most people who were rooted when they installed the update have had to do a SBF flash in order to get things completely working correctly again.
There's some information in this thread about flashing a SBF, along with links to the files required, further instructions, and further discussion about the issue (and others related to the update):
http://androidforums.com/droid-pro-support-troubleshooting/324907-factory-reset-not-working.html
Okay I was able to get this all sorted out, thanks for your help.
This was the process that ended up working in case anyone else has this issue.
I flashed the 2.26.20 SBF using RSD Lite like in the link above. This was two updates back from the most recent version 3.8.7 and actually brings you back to Android 2.2.
I had to factory reset the phone using Settings>Privacy>Factory Data Reset because it would not take the 2.26.60 update.
Then I was able to update to 2.26.60 and finally to the most recent 3.8.7.
The phone seems to be stable and fixed!
Awesome. Glad it seemed to have solved your problems. And yes, a factory reset after the SBF is a must to completely clear out all user data/programs. Having a SBF available is always a huge plus for correcting any seeming uncorrectable issues.
