Probably not a Pro problem directly, but I will start here.
Z4rooted the phone without a problem and happily used it for months, then along came a system update. I did not have the phone with the update was applied(a friend was using it and just answered yes).
After the update it was unrooted.
I have tried over a dozen times to re-root with the app and everytime it reboots or locks up when it gets to the "opening root shell" part of the process. I have tried un-rooting as well and the same thing happens, locks up or reboots.
Has anyone experienced this problem?
android version 2.2.1
kernel version 2.6.32.9-g43f0589 e50256@ca25rhe85 #1
build version 3.4.2_80_v2_87
