That's not the question as I understood it. Android will automatically switch to WiFi. It won't turn WiFi on or automatically configure it for an access point that you've never used but it will automatically switch to WiFi and use it for data instead of 3G.It does not switch WiFi on for you automatically. You can set it up to do it with apps like Locale or Settings Profile.
I don't think that's true. Otherwise I wouldn't be able to receive calls at WiFi spots.WiFi switches off 3G.
Not true. At least, on the Droid it isn't. The Droid consumes more power transferring the same data over 3G.WiFi uses MORE power than 3G.
Agree on 3G consuming more power than wifi, especially if signal isn't great.That's not the question as I understood it. Android will automatically switch to WiFi. It won't turn WiFi on or automatically configure it for an access point that you've never used but it will automatically switch to WiFi and use it for data instead of 3G.
