D
Deleted User
Guest
I'm on Verizon and my "new every two" thing has expired. I'm looking to get an android smartphone, and I'm leaning towards the Droid X but there are some minor problems I have with it. First off is the shutter button, I plan on using Google Goggles a lot and I heard the shutter button was really hard to press, and that there was no on-screen shutter. Second is the GPS, I plan on using it a lot for navigating and I heard it disconnects with the satellite unexpectedly, which may be a problem when I'm out on the road. If someone can reassure me that these aren't really issues at all or that I don't need to worry about them, otherwise I may just go with the Motorola Droid which was my other choice. Thanks for your time.
