Here is the latest version of my theme. There are still some things that i would like to change but i wanted to put it out there and get some feedback. Enjoy '
Requirements.
Droid X - Duh...
Froyo 2.3.15 (not sure if it works on anything else)
Deodexed
Root
AGAIN THIS IS STILL IN PROGRESS
*********** MAKE A NANDROID FIRST *************
Download the file
(rename to update.zip and plop on your SD Card)
Install using Koush's recovery (make sure you MOUNT SYSTEM)
(IF you don't know what any of this means, please DO NOT INSTALL THIS!)
For those of you interested in the Widgets etc used in this theme, please follow this thread, i will release details soon. It is better as a complete theme. So when this comes out of beta stage then i will release all the addons.
Thanks for your time. Please comment, good or bad (as long as its constructive)
Thanks,
KraYzeE
oh yeah... I dont claim that i did ALL the graphics in this, though i did do a LOT, so if you see some of your work I would be happy to credit you. I am not trying to steal your work. Trust me, I know what goes into it.
Requirements.
Droid X - Duh...
Deodexed
Root
Download the file
Thanks,
KraYzeE
