armstrong875
I rooted my x2 and a friend took it and updated the software... I still have the superuser app but i used the root checker app and it says I don't have root access how can I return it to normal without it getting bricked
Are you trying to return the phone? Since you now have the update all you have to do is a factory reset. Start - settings - privacy - factory data reset.I rooted my x2 and a friend took it and updated the software
will this get rid of the super user app and be as if it was never rooted?
