Droidlight LED Flashlight: Straightforward, does what it says, does it well
mrcizzo
Phone: Motorola Droid
This is one of the first apps I downloaded as soon as I heard my phone had a flash. This app is actually featured in the Verizon section of the Android Market for Verizon users.
This app does what it says perfectly and makes it very easy to do it. Turning it off and on isn't hard either especially when you can't see the screen too well either. Just tap on the lightbulb and off you go!
What's also nice is that the app notifies you via the Status bar if you close the application while the light is still on in case you forgot to tap that light bulb again.
Definitely would recommend this to anyone who has a Droid and doesn't want to scratch their car with their keys hah.
