dropped and won't turn on
  • Start date Start date
A
Android Question
Guest
Okay so i drooped my LG optimus L9 phone at the dollar store..and since then it wont turn on..neither will it charge! Sometimes when i try to turn it on it just shows the logo sign LG then turns off. thers no broken pieces or anything. And when the logo sig come up there is no screen cracks everything looks clear. PLEASE HELP.
Hi and welcome to Android Forums!
Sorry to hear your phone took a dive. It sounds like your phone has suffered some internal damage that isn't visible from the outside. A repair facility will be able to professionally open it, check it out and offer advice on whether it is cheaper to repair or replace. Hope this helps.
It's great to have you here :)
