I was wondering if anyone could tell me what i might need to fix my phone. It charges it vibrates and the bottom lights up but not the screen. What do i need or is there a repair shop. i think the phone is still under warranty. i got it in november.
Your warranty usually doesn't cause damage due to the result of the user. If you have insurance I would file a claim with the company.
First thing I would do in that situation is take the battery out and put the phone in a bag of uncooked rice for a day or so to try to soak up as much water as possible. You should have left the battery out because the damage occurs when you try to use it when its got water inside.
