found this, since we can't easily remove the battery, good luck
Correct Answer
by jasnmar on Aug 3, 2010 1:06 AM
This usually means that the phone isn't making good contact with the battery. Check to make sure that the battery contacts are clean, and that the battery is seated properly.
jason
