Root DSP Manager No ROM Help
hradek422
Okay, here's my situation. I really want to use DSP Manager on my D2G. I was using Liquid Smooth ROM 3.0, and it had it on there. I loved it. The ROM had too many bugs though, and I don't want to install CM7. I need to find a way to get DSP Manager installed and fully funtional on my rooted Droid 2 Global with no ROM. I have Root Explorer, and can move anything I need into the lib folder on the phone, I just need to know what files to move. *Note* I have taken the audioflinger.so from the Liquid ROM and put it in system/lib. I also took DSP Manager and put it in system/apps. This caused a bootloop and I had to restore. I really just need to know how to modify my current audioflinger.so to use DSP Manager instead of the stock sound manager.
Does anybody have any suggestions?
*EDIT*
I'm running Android 2.3.3 version 4.5.607, in-case that matters.
