S
SpecTM
Guest
Im pretty new to android studio development and I`m having trouble when building my apk, Im using google maps for location tracking and firebase with pubnub for notifications.
My problem came when I added firebase and started to add the dependencies, and when I tried to build I get this error: Duplicate class com.google.android.gms.location.places.zza found in modules jetified-play-services-places-9.6.1-runtime.jar (com.google.android.gms
lay-services-places:9.6.1) and play-services-places-placereport-17.0.0-runtime.jar (com.google.android.gms
lay-services-places-placereport:17.0.0)
App Gradle:
apply plugin: 'com.android.application'
apply plugin: 'com.google.gms.google-services'
android {
compileSdkVersion 28
buildToolsVersion '29.0.2'
defaultConfig {
applicationId "com.parse.starter"
minSdkVersion 17
targetSdkVersion 28
versionCode 1
versionName "1.0"
testInstrumentationRunner "androidx.test.runner.AndroidJUnitRunner"
multiDexEnabled true
dexOptions {
javaMaxHeapSize "4g"
buildTypes {
release {
/*minifyEnabled true
proguardFiles getDefaultProguardFile('proguard-android.txt'), 'proguard-rules.pro'*/
minifyEnabled false
proguardFiles getDefaultProguardFile('proguard-android-optimize.txt'), 'proguard-rules.pro'
dependencies {
implementation 'com.parse.bolts:bolts-tasks:1.3.0'
arse-android:1.13.0'
implementation 'com.android.support:multidex:1.0.0'
implementation fileTree(dir: 'libs', include: ['*.jar'])
implementation 'androidx.appcompat:appcompat:1.1.0'
implementation 'androidx.constraintlayout:constraintlayout:1.1.3'
implementation 'com.android.support:appcompat-v7:28.0.0'
implementation 'com.android.support.constraint:constraint-layout:1.1.3'
implementation 'com.android.support:support-v4:28.0.0'
implementation 'com.android.support:design:28.0.0'
implementation 'androidx.navigation:navigation-fragment:2.0.0'
implementation 'androidx.navigation:navigation-ui:2.0.0'
implementation 'androidx.lifecycle:lifecycle-extensions:2.2.0'
testImplementation 'junit:junit:4.12'
androidTestImplementation 'androidx.test.ext:junit:1.1.1'
androidTestImplementation 'androidx.test.espresso:espresso-core:3.2.0'
implementation 'com.google.android.gms
lay-services-maps:17.0.0'
lay-services-location:17.0.0'
implementation 'com.android.support:multidex:1.0.3'
implementation 'com.android.support:cardview-v7:28.1.1'
implementation 'com.github.ar-android
rawRouteMaps:1.0.0'
implementation 'de.hdodenhof:circleimageview:2.2.0'
implementation 'com.android.support:recyclerview-v7:28.1.1'
implementation 'nl.psdcompany:duo-navigation-drawer:2.0.8'
implementation group: 'com.pubnub', name: 'pubnub-gson', version: '4.31.0'
implementation group: 'com.fasterxml.jackson.core', name: 'jackson-core', version: '2.9.2'
implementation group: 'com.fasterxml.jackson.core', name: 'jackson-annotations', version: '2.9.2'
implementation group: 'com.fasterxml.jackson.core', name: 'jackson-databind', version: '2.9.2'
implementation 'com.github.jd-alexander:library:1.1.0'
implementation 'com.google.firebase:firebase-messaging:17.3.3'
Module Gradle:
// Top-level build file where you can add configuration options common to all sub-projects/modules.
buildscript {
repositories {
jcenter()
google()
dependencies {
classpath 'com.android.tools.build:gradle:3.5.3'
classpath 'com.google.gms:google-services:4.2.0'
allprojects {
repositories {
jcenter()
google()
maven{url "https://jitpack.io"}
task clean(type: Delete) {
delete rootProject.buildDir
ext {
compileSdkVersion = 28
buildToolsVersion = "29.0.2"
minSdkVersion = 17
targetSdkVersion = 28
App Gradle:
android {
defaultConfig {
minSdkVersion 17
targetSdkVersion 28
versionCode 1
versionName "1.0"
dexOptions {
buildTypes {
release {
minifyEnabled false
dependencies {
Module Gradle:
buildscript {
repositories {
jcenter()
google()
dependencies {
allprojects {
repositories {
jcenter()
google()
ext {
minSdkVersion = 17
