Novice App User
Hi. I have a Moto E6 phone with Android version 9. I inadvertently imported a second set of contacts into my phone. The phone app only shows one set of contacts, bu the contacts app shows the duplicates. I want to merge or safely remove the duplicates.
Online I see lots of articles telling me to use the merge option in the contacts app, but there is no merge option. I thought about just deleting the duplicates, but I was concerned about if this was safe. Part of my concern is that I have not just used the contacts phone numbers for calling people, but also for texting, and I was concerned that somehow if I deleted a duplicate contact that I had used to text with (the original contact that existed before I imported the duplicate), that the texts that I had created with that contact's number would be deleted as well.
As you can tell, there is a lot I don't understand about my phone, and would really appreciate any help I can get.
Thanks.
Thanks.
