Dvds on android help
Hello I have copied all my dvd's to my external hard drive,I then plug my hard drive in to my android media player which is a minix neo x5,the media player does recognize the hard drive but I cant find an app that will play my dvds straight from the hard drive,any one have any ideas ?
yes i have tried mobo player ,it shows the vob files from all the dvds but not the folders that they are in ,so you do not know which dvd you are playing,i need it to show all the folders ?
Android media players were not really made to play DVD MPEG2 .vob files. Probably because you can't plug a optical disc drive into an Android device. You might want to look at transcoding them into a more suitable and efficient format, like MP4 or DivX.
