Help E-mail battery life
How do you do it on your phone? Can't you do the same thing on your tablet? (And why would you want to? If you have the phone or tab with you, you can see that the level is getting low. If you don't, there's nothing you can do about it.
There is smart actions on my phone (razr) but not on my tablet. I need it less on my phone since I have it with me most of the time. The tablet sits unused for a while, then when I go to use it - BAM low battery. If I had it on my tablet it could tell me when the battery is getting low and I could charge it. I checked and smart actions says it is not compatible with my tablet.
If you want to see how much battery you have remaining change the setting so that the percentage remaining is always displayed in the upper right corner of your screen.
