Help Easiest backup for thousands of calls
Easter
Hi I'm not very good on my phone and I need to back up some files, including 8000 or so recorded calls, which I must not lose. It's a Huawei 20x 5G. It is absolutely stuffed full of really important stuff including the phone calls which I cannot lose, but if I try to back up to Google Drive it will only let me back up 40 or so at a time and it takes hours upon hours. I have in the past managed to put things onto a USB pendrive but the USB port is dodgy and it doesn't always transfer over. If the port breaks then I can't do anything at all obviously as I can't charge it. what is going to be the easiest quickest way for me to get copies of all this stuff? I'm terrified of doing something wrong trying to sort it ! Sorry to sound so totally daft.
Your phone model supports Nano Memory cards, yes? Do you have one?
Transferring your audio library to a NM card should be quicker than uploading to an online storage service. Then remove the card and copy your audio files to a PC (assuming it has a card slot or you have a USB card adapter).
Otherwise, while 8000 audio files are a pretty significant number of files, a big factor you're leaving out is the file size amount. If these are relatively low-res recordings than each file is going to reflect that in its file size, if these are higher res audio than of course conversely they'll each be a lot larger in file size. Also are they mono or stereo? That among other factors are relevant. The point being the total amount of those 8000 files is dependent on a mystery -- i.e. when it takes hours to upload a batch of 40 files that could mean those are high-res audio files, or it could mean you have a relatively slow broadband or cellular connection. Are you using WiFi (broadband, ISP-based) or mobile data (cellular, carrier-based)?
