Root Easy script to deblur cliq 2.1 roms and add live wallapers in one step
Ok,this is how to get the roms back to what 2.1 should be.It will remove blur and add live wallpapers. I needed to leave in the blur-services file,and a few others to get things to stop force closing,but for the most part,I think I fixed the issues.
You must have the drivers for your phone set up before starting.This assumes you are running 32 bit windows,if you have adb working on your 64 bit system,this will work for you too.
Instructions:
1: Download this zip file:Deblur.zip
2:extract the deblur.zip file so that all files in it are in one folder
3: Do a clean wipe and flash of the whatever 2.1 rom you want,go though setup,it doesn't matter if you sign in or skip,just get it to the home screen,install and pick launcher pro as default.
4:in the deblur folder,run the file "Run this to deblur your phone"
When it finishes booting up,you're done,and you have live wallpapers. same thing as all the other ones,polar clock,and most from the market work. nexus revamped looks like the original nexus.
I put most of the default (vanilla) android apps back in,but not all. If you want anything changed,let me know. I've been awake for about 22 hours now,so It will probably be at least a few hours before I go back to working on this.
I think I readded the google version of everything that I removed,but if you find something that is missing,tell me and I'll fix it.
here's a list of what it removes:
revolver.apk
truecountry.apk
hiphopofficial.apk
megamaid.apk
megamaid.odex
WeatherWidget.apk
WeatherWidget.odex
WmdrmDla.apk
WmdrmDla.odex
WmdrmWebpush.apk
WmdrmWebpush.odex
VoiceDialer.apk
VoiceDialer.odex
Term.apk
Term.odex
ToggleWidgets.apk
ToggleWidgets.odex
StatusWidget.apk
StatusWidget.odex
StickyNoteWidget.apk
StickyNoteWidget.odex
SocialMessaging.apk
SocialShare.apk
SocialShare.odex
QuickContactWidget.apk
QuickContactWidget.odex
Quickoffice.apk
MessagesWidget.apk
MessagesWidget.odex
Messaging.apk
Messaging.odex
MasterClearErrorReport.apk
MasterClearErrorReport.odex
IMPS.apk
IMPS.odex
ImDmPlugin.apk
ImDmPlugin.odex
ImOfflineService.apk
ImOfflineService.odex
FirewallService.apk
FirewallService.odex
FriendFeed.apk
DrmProvider.apk
DrmProvider.odex
Conversations.apk
ClockWidget.apk
ClockWidget.odex
BtLowPower.apk
CMP.apk
BlurAlarmClock.apk
BlurAlarmClock.odex
BlurContactsSync.apk
BlurContactsSync.odex
BlurEmail.apk
BlurEmail.odex
BlurEmailEngine.apk
BlurEmailEngine.odex
BlurHome.apk
BlurHome.odex
BlurSNMessagingEngine.apk
BlurSNMessagingEngine.odex
BatteryManager.apk
BatteryManager.odex
ArcPhotoworkshop.apk
ArcVideoTrimer.apk
MotoPerforManager.apk
and what it adds back (most taken from eclair2cliq alpha 5):
Term.apk
Music.apk
Mms.apk
Launcher.apk
LatinImeTutorial.apk
LatinIME.apk
Email.apk
DrmProvider.apk
Dock.apk
DeskClock.apk
CtsDpiTestCases2.apk
Calculator.apk
Development.apk
SpareParts.apk
Also adds the live wallpaper support frameworks.
if I understand correctly, i need a rooted cliq for this, right?
Mine got 2.1 from the non root method and when i run the remount line, it's said: Operation not permit, or something like that
I'm looking forward to trying this out. Do you need root for this? I'm getting ready to try the unroot / leaked 2.1 ROM.
Need to figure out ADB on 64-bit Win7 first, too - that's another story!
(I got the link to work, nevermind on the first version of this. Thanks!)
I ran this last night. The standard Android keyboard was missing (not a big deal because I use Swype) and the base home screen was missing (I think you did this on purpose - not a big deal because I use Launcher Pro). I do notice a bunch of stuff still loaded from Motorola. Seems to have provided a bit of a speed increase. Thanks!
