Root Easy way to root D320n (works on V10d, V10g...)
nypoon
EDIT: PurpleDrake Lite should work on every fw version where Towelroot fails
http://forum.xda-developers.com/lg-g3/development/root-root-lg-g3-easily-purpledrake-lite-t2821000
__________________________________________________________________________
Greetings, I've tried various methods for bl unlock posted here and xda, but none of them work for me.
My device is D320n, EU if that makes difference. Here are some outcomes of unlocking methods:
  • LG Laf Recovery Multitool - pressing unlock (z) writes something in console for like 0.001s then it disappears, while phone reboots normally
  • Fastboot way (MikeHoncho's post) it can't find laf.img, nothing happens, going to fastboot mode brings up LG's download mode
I haven't had any luck with rooting either, towelroot says the device isn't supported.
Here's info screenshot
I've spent too much time on this now without a clue and my head's gonna explode in a minute. Should I just flash another fw, V10c for example?
Any help is appreciated <3
Can't you just downgrade to 10b from ms323? I'm not sure that'd work and it might brick it. You should tell someone experienced with this phone and see if it's possible. Also do NOT flash 10c, you'll get the same results. Only 10b and 10a are rootable.
@LitrosNub I can try that, I mean, what's the worst that can happen? Soft brick right? And that can be resolved by flashing original fw through LG flash tool. correct me if i'm wrong
I found it on one serbian android forum and they mentioned even V10g being rootable using this method. That might as well be it.
