Easymoney - not that confidential as it should be...HELP!
annlee
Hi everyone,
I've just bought the Easymoney app and I've noticed that I can't delete/ disable the Easymoney widget :mad::mad::mad:. I don't want people to see how much money I have and I thought that having a password will protect that, but it doesn't.
Any ideas on how to disable the widget as it showing all confidential information?
Thanks in advance.
You just need to "long tap" (tap and hold until you can move the widget around the screen) the widget and drag it to the bottom middle on to the trash can.
This will remove the widget from your home screen.
Rodney and Aedans Dad, thanks for your input but I know how to remove a widget from the home screen :) . My the problem is different. I have a password for Easymoney so no one can see what I've been adding there but when you look in the widget list, you can easely add the Easymoney widget on the homes screen and see what balances I have!
So if somebody plays with my phone, they can add the Easymoney widget and see my back accounts. I hope that explains my problem...
Thanks again and I hope somebody can let me know if I can do something about this.
Use Applock. when someone clicks on it, even the widget, it will ask for a password.
Even if I use Applock, people can see my balance as the widget dispay that information. Also, you can use the arrow (see the pic attached) to see other accounts.
Any ideas?
now we all see your balance :)
appblock should block it if you take the widget off your homescreen then if you try and put it back on appblock will kick in
