Apps Eclipse problem!!!
Cole.
When I try to run my app, I get this message:
I know it's not the "you have spaces in your installation destination folder thing." problem, because I already fixed that.
Check your code to see if you haven't mistakely used a java key that is also a keyword for Android. When I first created my app, I kept on mistakenly opening up other applications because I wasn't familiar with the Android keywords.
