I've had the S6 Edge+ a couple of weeks now and so far I love the phone, but I have to admit I was disappointed with the edge screen, specifically with the "People edge" and "Apps edge" being limited to only 5 contacts and 5 apps. Anyone else feel the same way?
When you go into Settings for Apps Edge you are allowed to add on more column which totals you up to 10 apps.
Where exactly is this option? I looked and didn't see it.
Precondition:
Home Screen
Reproduction:
1. Swipe Edge Screen
2. Go to Apps Edge
3. Select Edit
4. Observe (At the top right hand side) You will see "ADD COLUMN" I am using VZW. May differ from carriers.
There's also a remove column option as well.
Hope this helps out.
I too am using VZW, but I don't see that option in the edit menu. . Are you rooted? maybe that's why I don't have that option. I've included a screen shot of what I see.
