Edge tasks
InfernalByte
Android Expert
How do I add icons to the tasks panel that aren't there? There's an instruction about adding the app to the home screen but I don't understand.
If on your home screen in the right hand side, you have a different colored box, like mine is a different color of white. Drag it towards the middle Of Your screen. It will open your edge. Look at left hand bottom of the screen and you will see a gear. Click it and there and you can change the options of edge and what you see there..
Once you get it set up you can push your home button, if you open edge back up, swipe your screen left or right and it will show you all the edge screens you have picked.
Hope this helps you. :)
Maybe I should have put it in simpler terms, how do I populate the menu, to populate the tasks edge that you have just pointed at?
